Edelbrock High Flow Intake Help. EDL-3860
Old Dec 16, 2011 | 11:00 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Hi guys. Here is another confusing situation. I have a EDL-3860 High Flow intake base. I noticed that there was 2 different EDL-3860 intake bases. One has the fitting on the driverside which a hose connects to for the PCV valve on the driverside. The other (mine) has no hole for a fitting for the PCV Valve hose. So what the heck am I supposed to do? Could I run a "T" inbetween the brake booster and the plenum so that the vacuum can pull out the crank case fumes?
Top picture is mine (yellow arrow)....
edl3860.jpg?t=1324093426
Here is the fitting that is used to connect a PVC hose.
topvc.jpg?t=1324093772
Old Dec 17, 2011 | 12:29 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Edelbrock High Flow Intake Help. EDL-3860
I don't see any reason why you can't tee of the booster hose.
Raul.
Old Dec 17, 2011 | 01:44 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
That was the early base, it had a drilled and tapped hole in the runner.
It lined up with the hole passage in the base.
Old Dec 17, 2011 | 08:24 AM
Dyno Dan, I've read so many topics about you. But never did I realize that I lived fairly close to you back in 2005-2006. I use to live in Rialto, then I moved to Hemet. Unfortunately I moved back down to the Imperial Valley. Did you feel the 2010 7.2 Easter Earthquake? That was intense. I was only 40 miles away from the epicenter. Wow. What an earthquake. Anyways, would it be okay to t-off the brake booster line close to the plenum for the PCV valve?
Old Dec 17, 2011 | 10:11 AM
Dyno Don's Avatar
Raul.
Well one reason is because that is a constant draw, reducing the vacuum to the brakes.
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
