fighting to keep it running
Old Dec 22, 2011 | 02:06 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
hey all, have a 1986 iroc-z 305tpi. it has new cap, rotor, plugs, wires, ect ect. everythings almost new. anyways on cold starts you have to fight to keep it running or it'll die out. almost like its a clogged fuel filter. (which i havent yet replaced) however once its up to temperature it runs as great as a brand new car. any ideas on why it wants to die on cold starts? its not just after i replaced everything, its always been that way. with the cold weather coming around now takes a bit longer to get up to temp. any opinions are great. thanks once again
-jeff.
Old Dec 22, 2011 | 06:31 AM
ex-x-fire's Avatar
Re: fighting to keep it running
That year had a 9th injector or cold start injector. See if its getting a pulse.
Check your fuel pressure & leak down rate.
Old Dec 22, 2011 | 11:30 PM
jeff_blake's Avatar
wheres the 9th injector located? i never seen a 9th one on this engine. may be wrong though
Old Jan 10, 2012 | 12:14 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
he means your cold start injector,its on the left side of the FI runners next to the intake
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
djmarch
Aug 9, 2015 05:27 PM
