My third brake light and hatch light doesn't work.
Old Dec 24, 2011 | 08:17 PM
Xanity's Avatar
Car: 1989 Camaro
Engine: 2.8 MPFI
So after I replaced the hatch motor in my 89 with a brand new one and got it working (flawlessly, might I add), I realized both my third brake light and hatch light aren't working anymore, which they were working 100% perfectly before this hatch motor surgery.
I checked the fuses to make sure none of them were popped, and they are all fine. Anyone have any ideas why these two lights aren't working anymore? I'd appreciate any input. Merry Christmas everyone!
-D
Old Dec 25, 2011 | 11:38 AM
89shane350's Avatar
Car: 1989 Chevy Camaro IROC-Z
Transmission: 700R-4
Axle/Gears: Borg-Warner rear axle 2.77
Re: My third brake light and hatch light doesn't work.
-D
did u disconnect the battery when doing so? if not u might have popped all the bulbs, try changing just the hatch one, if it works then get the others.
also check the grounds and thatt everything looks hooked up, might be loose from your monkeying around in there
merry Christmas
Old Dec 26, 2011 | 12:52 PM
Xanity's Avatar
Car: 1989 Camaro
Engine: 2.8 MPFI
I didn't unhook the battery, no, but you may be right about the wires. The bulbs aren't burnt out, I tried the hatch light one in the dome light and it works. The lights in the third tail light are brand new. I haven't had time to open it back up, but I'm fairly sure I triple checked all the wiring before I put it back together.
Old Jan 9, 2012 | 11:52 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
the contact pad is out of alignment/disconnected
Old Aug 26, 2012 | 12:45 PM
1992rs305tbi's Avatar
I know this is an old post but im having the same problem. Can somebody tell me where the contact pad would be????
Old Aug 26, 2012 | 01:09 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
