I need only 2 cylinderhead bolts!!!!
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Ive looked all over the internet for a pair of cylinder head bolts. I only need 2 dog gone bolts. Where the heck can I find only 2 aftermarket 3/8 small headbolts??????
Re: I need only 2 cylinderhead bolts!!!!
Do you need head bolts, or 3/8" bolts?
If you just need 2head bolts, you probably won't find em on the Internet. Junkyard is probably the best place.
I dont wanna get used bolts. They are more brittle and prone to failure.
Problem is that I had a leak for quite some time (9 months). I decided to get dirty and I got under the camaro. After search and destroy, The leak is from the bolt next to the 8th spark plug. So Im pretty sure the bolt has waater damage.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Head didnt blow off. The coolant is leaking in the rear of the head and im sure there is water damage. So Im gonna remove the 2 rear lower bolts and retorque to see if I can seal up the leak. If it fails, then Im gonna get me some heads with copper head gaskets.
Did you run a tap through the threads and coat the threads of the bolt with a sealant before installing them? Both processess are important to properly seal up and torque the bolt.
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
