harmonic balancer installed wrong?
Old Dec 28, 2011 | 10:40 PM
Bigdeerock's Avatar
Hey guys,
I brought my #1 to TDC. I work alone so i just removed the #1 spark plug and felt around in there with a small flat head until I could feel the piston at the top ( timing mark is at 0). Anyway the rotor button on my dizzy is pointing at the 7 o clock position instead of the 530. Is that where it should be? PO rebuilt the engine is it even possible to install the HB improperly?
Old Dec 28, 2011 | 11:46 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: harmonic balancer installed wrong?
No, the HB is keyed to align with #1 ,TDC when the cam/crank gear timing marks are at the 12 o'clock position.
If the rotor is not pointing at the #1 terminal of the dizzy when the HB is aligned with DTC then it should be pointing at #6, rotating the crank another complete turn should point the rotor at #1. If not either #1, or #6 then timing is off.
Old Dec 28, 2011 | 11:49 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
If the balancer mark lines up with zero on the timing tab with #1 exactly at tdc, that's how it should be.
From that position, it's 'traditional' (for easiest of wire routing and vac canister fit if u a vac adv dist), to install the dist so that the rotor is pointing at #1 cylinder, but is can be installed pointing anywhere. Just so long as the #1 plug wire post on the dist cap lines up with the rotor wherever it points.
Or you could be looking at the other instance of #1 tdc, at the start of the inlet stroke.
Old Dec 29, 2011 | 07:19 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
With the timing mark lined up, piston 1 and 6 (on a V8) are at TDC. Either one could be at TDC on the compression stroke You'll need to remove the distributor cap to see which one has the rotor pointed at the plug wire terminal.
Old Dec 29, 2011 | 09:30 AM
Darth 93's Avatar
Car: 1983 Z/28, 2017 Camaro SS 1LE
Engine: L69
Transmission: 5 Speed
Mine harmonic balancer slipped ( inner ring to outer ring), so the markings were all wrong. had to replace the balancer.
evilstuie
Jan 9, 2020 08:29 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
nuggie
Aug 25, 2015 01:27 PM
dhonda200
Aug 11, 2015 11:50 PM
sonu1975
Aug 11, 2015 08:38 AM
