87 camaro Iroc z headlights suddebly stopped working
Car: 1987 Camaro Iroc-Z Z28
Engine: 305 FI
Transmission: 5Speed
Axle/Gears: Stock
I have an 87 Camaro IROCz 305 tpi and my turn signal switch (with the high beam.) Started failing and making my high beams flash rapidly along with my headlights. And now they don't work. What fuse should I check? And is this a cpmmon problem?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
☼ ☼ Light Right ☼ ☼
If they flash on & off it’s due to the circuit breaker inside the pull-for-on headlight switch cycling.
The cause is improper headlights or a worn breaker.
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Happy Racing!
Ghettobird52
Jul 5, 2024 11:18 PM
Linson
Aug 21, 2015 02:12 PM
mustangman65_79
Aug 11, 2015 03:17 PM
