Cam and head selection help
Old Jan 2, 2012 | 07:33 PM
Badasscamaro346's Avatar
Car: 87 camaro
Engine: v8 carb'ed
Transmission: 5 speed
I have an 87 Camaro with an lb9 and 5 speed. Current mods are headers, cat delete, flowmaster exhaust, edelbrock intake, and edelbrock carb. I finally got the car on the road and it runs pretty good but I would like to get a little more power out of it. I don't really rave the car often but I do like to play with it here and there.
I have done some research and it looks like the lt1 cam would be a good swap but wanted to get some opinions from everyone else. I use the car as my daily driver so it needs to be streetable. Also are there any decent 305 heads that flow better than our stock ones that i could pick up at the junkyard or online pretty cheap?
Thanks for the help guys!
Old Jan 2, 2012 | 09:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The only heads that would flow better than your current heads would be 350 Vortec heads, which have larger chambers and require a Vortec-specific base.
The LT1 cam is a little better, but you'd do even better with an aftermarket cam like the Comp XFI series. Plan on new valve springs, though.
Frozer!!!
Jan 19, 2024 04:55 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
michealleger
Aug 26, 2015 03:29 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
