Turn Signal Solid
Old Jan 3, 2012 | 12:02 PM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Turn Signal Solid
Passenger side cluster indicator is solid when parking lights are on or when turn signal activated. Passenger front and side bulbs don't turn on. Rear turn signal bulb turns on and stays solid when parking lights are activated. Hazards work but passenger front lamp looks dim. Ideas?
Old Jan 3, 2012 | 12:28 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Re: Turn Signal Solid
I'm in the same boat as you except its my driver side and it only stays solid when the turn signal is on and it normally only happens when it is below 60 degrees outside.
Old Jan 6, 2012 | 02:12 AM
Axle/Gears: Stock
Any other opinions?
Old Jan 6, 2012 | 09:54 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
From Chilton manual page 6-43
Turn signals light, but do not flash - replace flasher
//RF
Old Jan 6, 2012 | 02:52 PM
Axle/Gears: Stock
They don't turn on though
Old Jan 6, 2012 | 03:18 PM
RFmaster's Avatar
Car: 75 Beast
Check the bulbs that are not on. These may have burnt out. The Dim light might be the wrong type.
//RF
Old Jan 6, 2012 | 03:51 PM
Axle/Gears: Stock
//RF
All bulbs replaced with exact matches though. Pops thinks its a ground issue.
Old Jan 11, 2012 | 04:48 PM
albertgeorge1's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
check all the fuses
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
383cam
Sep 9, 2015 06:01 AM
Stryker412
Sep 7, 2015 09:11 AM
