a complete roller set up
Old Jan 4, 2012 | 09:01 PM
dame28's Avatar
Car: Chevy Camaro
Engine: 5.3 LS carb'd
Transmission: 700R4 on deck to be rebuilt
Axle/Gears: 3.08
I want roller lifters and rocker arms on my 350 motor I have decided on a Lunati cam and lifter kit, to replace the Comp Cam flat tappet set up the previous owner installed. my question is will a have to get new push rods because I know I need new springs seeing as though the current cam is a 400 lift and the new will be a 500+
Old Jan 5, 2012 | 07:06 AM
Re: a complete roller set up
Yes you will need new push rods, but not necessarily because of the springs.
Roller lifters are usually about .400" taller than flat lifters, meaning you need push rods about .400" shorter more or less.
Old Jan 5, 2012 | 07:15 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
You order pushrods of specific length last, because you have to measure accurately to get the valvetrain geometry correct. Everything else has to be bolted together and in place in order to measure. This is one of the more complex procedures in setting up a valvetrain.
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
Dialed_In
Aug 20, 2015 01:45 PM
