Any1 Have Same Engine who can help
Old Jan 6, 2012 | 09:48 AM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
I have a 2.8L V6 in my 1991 camaro rs and i am going to be replacing the fuel pressure regulator, does anyone with the same engine know what type of head gasket to use or any other usefull info
Old Jan 6, 2012 | 12:34 PM
ex-x-fire's Avatar
Re: Any1 Have Same Engine who can help
Why are you asking about head gaskets? You onlyl have to remove the upper parts of the intake manifold to change the regulator.
91 should have a 3.1L in it.
Old Jan 6, 2012 | 02:07 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
well not head gasket but the manifold gasket i meant.
Old Jan 11, 2012 | 04:51 PM
albertgeorge1's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
if its a tpi go to an orielys and ask for a intake gasket kit
Old Jan 11, 2012 | 08:48 PM
Damon's Avatar
The 2.8 intake is a "sandwich" affair. Uppper, middle and lower. Gaskets between each of them. I believe you will only need to remove the upper and middle layers of the "sandwich" to replace the FP regulator. Might even be able to do it without touching the intake at all, but I'll defer to those with more experience on that engine to chime in about the actual R&R procedure.
Old Jan 11, 2012 | 08:55 PM
ex-x-fire's Avatar
Looks like the top has to come off, might change the middle gasket & injector O rings while your at it.
Attached Thumbnails Any1 Have Same Engine who can help-2012-01-04_15-15
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
