Third gen axle to fourth gen swap
Old Jan 7, 2012 | 12:26 PM
89_camaro's Avatar
Car: 89 camaro
Engine: 355
Transmission: 700r4 w/huges 3000 stall
Axle/Gears: 3.73 posi
I have an 89 camaro with a 10 bolt in it. A friend of mine wants to buy it for his fourth gen since his recently took a few teeth off the gears, my question is are the third and foruth gen rear suspension setups the same other than breaks such as coil spring mounts control arm/panhard bar mounts and what not. hoping to just switch them out in the next few days if they are. Any information would be awesome thank for the helop
Old Jan 7, 2012 | 12:27 PM
AmorgetRS's Avatar
Re: Third gen axle to fourth gen swap
Suspension is the same, width of the rear axle is not
Old Jan 7, 2012 | 12:33 PM
89_camaro's Avatar
Car: 89 camaro
Engine: 355
is the third gen more narrow or is it the other way around ad will it still work if we do the swap?
Old Jan 7, 2012 | 06:00 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
forthgen rears are four inches wider than third gen.two per side.
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
E Rod
Aug 28, 2015 05:17 AM
InfinityShade
Aug 22, 2015 08:00 PM
