Horn?
Old Jan 10, 2012 | 01:11 AM
BT85's Avatar
Car: 85 Camaro Z28
Horn?
Hey guys, when I bought my 85 z28 the horn did not work. I know it was not connected to the steering wheel. I don't know if the guy before me took it out or not or it just got disconnected or something. So I'm wondering if anyone knows where the horn itself is located on this car so I can check it out. someone please answer lol thanks
Old Jan 10, 2012 | 01:13 AM
Alwaysboosted's Avatar
Car: Turbo Z31, RX7, and 2 F-bodies
Engine: 1.LS1, 2. L98
Transmission: 1.4L60E, 2. 700r4
Axle/Gears: 1. 3.23, 2. Unknown
Re: Horn?
I just replaced the entire steering column on my 1988 Firebird.
First/easiest place to check is pop off the cover on your steering wheel (if it's the same as mine, square panel between the buttons). Underneath you'll see red wires leading to your horn button and a black one that grounds out on your steering column/center.
Not sure if there's a fuse for the horn, but look at simple fixes before anything else.
Old Jan 10, 2012 | 07:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Horn?
Below.
Old Jan 10, 2012 | 07:05 AM
JamesC's Avatar
Re: Horn?
There is a fuse. If the dome light is functioning, the fuse isn't the culprit. If not, fuse.
The horn 'wire,' which has two small plastic arms, passes through the turn signal cam and is held in place by inserting an arm in a notch in the cam. Occasionally, the notch will be broken so that the wire can't make contact. The wire and cam can be seen in the following link:
https://www.thirdgen.org/forums/susp...-steering.html
EDIT: There are two types of horn wires, depending on steering wheel:
http://www.moderndaymuscle.com/inc/sdetail/160/12331
http://www.moderndaymuscle.com/inc/sdetail/160/635
JamesC
Old Jan 11, 2012 | 07:54 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Horn?
the extreme left front corner of the engine compartment is where you will find them,if they are still there
Veaceonee
Sep 29, 2016 08:15 PM
Fox118
Sep 1, 2015 04:07 PM
tc7761
Aug 30, 2015 09:45 AM
Stauf
Aug 24, 2015 08:31 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
