Vin Number check *PLEASE HELP*
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
Just before i post i would like to say if this isnt allowed please just erase it and warn me, i love this site and dont want to get banned. ok so this is the question. is there anyone that would be able to do a check on my car with a vin number? maybe a carfax or something? anything would do? thankyou.
Re: Vin Number check *PLEASE HELP*
Just call a local police department and tell them your buying a car and would like them to check the VIN to make sure everything matches up and its not stolen. I do this everytime i buy a car.
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
the reason i want it is to see what actuall year and the stock engine it had so not much.
91 was sposd to have a 3.1L... well i heard around town that mines a 2.8L and im so frickin confused
Car: check
Engine: check
Transmission: check
Look at the VIN through the windshield, the 8th position is a T for the 3.1l engine from the factory.
The 10th position is the year of the car, M for a '91. N for a '92.
To check if the engine is the original is a little tougher, but doable. On the passenger side of the block, right above the motor mount is the VIN derivative. The last 6 digits should match the last 6 digits of the vehicles VIN. If so then it is a 3.1l engine and is the original.
The year of the engine is the 2nd position of the VIN derivative. Again with M being a '91 and N being a '92. I would assume that you could go backwards through the alphabet for the previous years.
Would need to do that if the VIN on the block doesn't match the vehicle VIN. The '90 - '92 MPFI f-body's got the 3.1l engine.
RBob.
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Ok. so here it is. if anyone could decode it or even better, get like a carfox on it. :
1G1FP23T9ML179353 SO any help would do and if anyone would be kind enough to get me a carfax. thanks
Car: 1987 IROC-Z
Engine: 5.7L
AutoCheck found 17 records for this 1991*Chevrolet*Camaro RS!
VIN: 1G1FP23T9ML179353 Engine: 3.1L V6 MPI
Style / Body: Coupe 2D Country of Assembly: United States
Car: 1987 IROC-Z
Engine: 5.7L
records cost anywhere from $30-$50...depending on if you're wanting a DMV print out, or carfax.
Car: MSD Dist., Crane Hi 6 ignition
Engine: 350 - 50 over, S/R Torquer Heads
Transmission: T56 - Originally a 700R4
Axle/Gears: 9 bolt posi with 370
1991 Chevrolet Camaro RS Coupe
GeneralEquipmentColors
VIN 1G1FP23T9ML179353
Year 1991 Engine Type 3.1L V6 OHV 12V
Make Chevrolet Driveline RWD
Model Camaro Ground Clearance No data in.
Trim Level RS Coupe Front Brake Type Disc
Manufactured In UNITED STATES Rear Brake Type Disc
Body Style COUPE 2-DR Anti-Brake System Non-ABS
Transmissions: 5-Speed Manual Overdrive & 4-Speed Automatic Overdrive
Standard Seating 4
MPG Hwy 27 miles/gallon Optional Seating No data
MPG City 17 miles/gallon Tires 215/65R15
Dealer Invoice No data USD Wheelbase 101.00 in.
MSRP $11,650 USD Curb Weight No data lbs
If you want a digit by digit breakdown go here:
http://www.fbodydomain.com/vin/vin.asp
Standard Seating 4
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
