vortec heads
Old Jan 11, 2012 | 08:54 AM
c4ta's Avatar
Car: 89' GTA,98' z28
Engine: 350tpi/ls1/ls6
Transmission: 700r4/4L60e
Axle/Gears: BW 3.27/3.42
vortec heads
I just picked up a set of 062 heads that have all brand new stock parts on them and wondering if I am going to have a problem running a 2032 cam. Only reason I am asking is I have searched and see a few different opinions on the max lift..450 and some say .480. Let me know what your thoughts are. Thanks
Old Jan 11, 2012 | 12:35 PM
ex-x-fire's Avatar
Re: vortec heads
I'd talk to comp cams, they make some springs that help you get more clearence.
Old Jan 11, 2012 | 12:56 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: vortec heads
The valve springs is not the cause of the clearance issue. It the retainer to seal clearance. The limit is typically .480 lift" before you run into issues. If you are referring to the crane 2032 compucam with .452"/.465" lift than you should be good. You may want to consider changing the valve spring, but that cam is mild enough you might be able to get away with stock springs. A common upgrade at my shop for a cam that size on vortec heads is GM ZZ4 valve springs. Direct replacement.
Old Jan 11, 2012 | 01:50 PM
c4ta's Avatar
Re: vortec heads
Ok will do thanks.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
