nasty squeal when accelerating (not belts)NEED HELP!
Car: 1983 Trans am ws6
Engine: 305 HO
Transmission: wct5
I just did put a new motor in 83 trans am, i am 99% done with everything to get it inspected and start driving but I keep getting this squeal everytime im driving and go above 2 thousand or in reverse turning it and when you hit the gas it squeals. it dosent squeal while your reving it up. I took off all the belts too see if they were the problem but it still squeales Any suggestions will help. Thanks, Eric
Engine: 305 HO
Transmission: wct5
Re: nasty squeal when accelerating (not belts)NEED HELP!
It sounds like its coming from the transmission i dont know what would make it squeal like that
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Do you have a manual or automatic transmission?
Engine: 4++,350 & 305 CIs
If its a auto did you get the TQ converter fully seated ??
RedLeader289
May 28, 2019 01:47 PM
