oil lines need asisstance asap
Old Jan 21, 2012 | 09:42 PM
cactusman92's Avatar
Car: 1991 Chevrolet Camaro Z/28 (Project
Engine: 5.0L 305
Transmission: 700R4 W/ B&M shift kit
i have a 91 camaro i literely just put the engine back together in the car i replaced the head gaskets so i have a oil pressure gauge but stock and after market the line to them decided to snap and now it is pissing oil everywhere. the line broke from behind the engine between that and the firewall i would like to know where the whole line comes from so i can plug it from a different area like it would be best to know where the whole line goes it ends up going through the firewall to the gauge but i really want to know where the other end starts any answer at this point would be helpful please and thank you
Old Jan 21, 2012 | 10:36 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: oil lines need asisstance asap
Top of the block right behind the distributor is a port that they may have tee off of.
Old Jan 22, 2012 | 01:50 PM
Engine: 5.0L 305
i have found it would it be safe to just block it off or get a little cap for it or would that pose any dangers to the engine in theory it only goes to a gauge but who knows
Old Jan 23, 2012 | 01:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not plugging it is dangerous. Plugging it is good.
Old Jan 31, 2012 | 01:08 PM
Engine: 5.0L 305
i am going to buy a little threaded cap to screw over it i was wondering if anyone knows the size i am going to need. its the part right behind the intake manifold that goes into the block
Old Jan 31, 2012 | 01:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The hole in the block is 1/8 NPT, the remnants of whatever was installed there could be almost anything.
solocus
Sep 2, 2015 12:14 PM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
