Engine Bay Cleaning
Old Jan 24, 2012 | 09:34 AM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
Engine Bay Cleaning
Ive been swooping around forums and have a question for my thirdgeners.
what would be the best way to clean my engine bay. 3.1 V6 MPFI. it is filthy
Old Jan 24, 2012 | 08:10 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Re: Engine Bay Cleaning
Get a can of engine cleaner... can be had for five bucks at any parts store. Spray it all over everything, scrub with stiff bristle brush if it's really dirty, rinse off with the hose. Try to avoid the distributor and coil; you can cover them with a plastic bag and tape if you're really worried but I've never had issues. Don't use a pressure washer because it can force water into weatherpack plugs and gaskets. Don't get water or cleaner in your intake, it will wreck your mass air flow sensor and potentially damage the engine if a large quantity gets in. Don't use the brush on your radiator as it will bend the fins.
Old Jan 27, 2012 | 08:57 AM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
ok. if i use gas as a cleaner for the heavy oil is that bad?
Old Jan 27, 2012 | 10:00 AM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Yes, I would not use gas to clean the engine bay. I would not use gas on anything that is painted.
Old Jan 27, 2012 | 10:44 AM
Mrs.Crasher0083's Avatar
Car: 88 Pontiac GTA and 4 Camaros
Engine: 5.7
If you dont care about the paint go ahead but I think a good degreaser would be better. Something like Purple Power. Either one will eat at the paint though. If you car about the paint......just use a good dishwashing liquid that is good on grease. It usually says it on the bottle. Use that and have a few different size scrub brushes and a couple old tooth brushes and scrub your **** off!!!! Good luck either way
Old Jan 27, 2012 | 02:14 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
alright ill stick with degreaser instead. just wanted to know a better way because my engine is pretty da** dirty.
as you can see
This is what im dealing with.
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
