Comp cam 12 246 3 input needed ASAP!!
Old Jan 25, 2012 | 07:11 AM
Sttn89's Avatar
Car: 89 caprice
Engine: 350 650 dp on roids
Transmission: 700r
Im in the process of buildin my engine and found this camshaft for a nice price with the lifters included.the set is used and states it is in excellent condition.should i find out if the lifters were labeled when they were removed to make sure they go back in the same or does this not matter.its a hydraulic flat tappet cam.
Old Jan 25, 2012 | 07:27 AM
skinny z's Avatar
Re: Comp cam 12 246 3 input needed ASAP!!
Wouldn't the cam in your 89 350 be a hydraulic roller?
Old Jan 25, 2012 | 08:30 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Also - used flat tappet - forget it. With lack of zinc in modern oils, these things need to be treated like glass, no telling if a used one was looked after.
FT lifters absolutely have to go back on the same lobes; I believe it's probably also equally important they go back in the same lifter bores (ie the same block it was broken in on) to maintain the exact conditions that lead to the wear pattern unique to each lifter/lobe pairing during break-in.
Old Jan 25, 2012 | 10:29 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Why go backwards? Your car came with a roller cam stock.
Old Jan 25, 2012 | 03:10 PM
Sttn89's Avatar
Car: 89 caprice
Transmission: 700r
Its for another motor im building that came out a 92 pick up which is a block that has the roller provisoins but comes with a flat tappet.the price made me consider it before i had the block made roller.thanks for the advice
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TreDeClaw
Aug 14, 2015 06:58 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
