timing??????
Old Jan 26, 2012 | 03:45 PM
marroboy88's Avatar
Car: 1986 Camaro z28
Engine: 383 stroker
Transmission: auto 700r4
timing??????
I need help setting the time on my engine... Its a 350 bored and stroked to a 383. It fires right up and runs strong its when you give it some gas it boggs down. Cant be far off but just cant get it right dead on. Any suggestions or answers will be greatly appreciated......
Old Jan 26, 2012 | 04:04 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: timing??????
check to see if your dist. is in right. turn your engine by hand til u hit TDC ,then see where your rotor is pointing. it should be pointing to no.1
Old Jan 26, 2012 | 04:23 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: timing??????
r u using a timing light?
Old Jan 26, 2012 | 08:53 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: timing??????
What engine? Computer controlled or not?
Old Jan 28, 2012 | 07:42 PM
marroboy88's Avatar
Engine: 383 stroker
Re: timing??????
No timing light.... Wasnt sure if it was a good investment or not. And its a 350 bored and stroked to a 383 no computer. Its not far off but just cant the distributer in the perfect spot seems like. Im gonna keep working with it.
Old Jan 28, 2012 | 09:00 PM
lethaldomestics's Avatar
Re: timing??????
Old Jan 28, 2012 | 09:11 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: timing??????
Get a timing light. Best investment to have. Then you know exactly where your at. You may only need to adjust 2 degree's, you cant hardly do that by ear.
Old Jan 28, 2012 | 09:41 PM
marroboy88's Avatar
Engine: 383 stroker
Re: timing??????
Thanks alot ill give it a shot
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
