Jumping Shifts
Old Jan 29, 2012 | 05:40 PM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
Jumping Shifts
Alright so quick story for answer
my brother had my car before me, used to race alot illigely, i have it now. when im driving the shift **** and the whole thing jump. what might be the problem here? something loose? it seems to slow my shifts down because the jump.
Old Jan 29, 2012 | 05:53 PM
'84thunder's Avatar
Car: 1984 Camaro sport coupe
Engine: 5.0(H/O) 305 carb'd
Transmission: TCI St. Fitr stge 2 700r4 man.valve
Axle/Gears: stock gears, Limited Slip
Re: Jumping Shifts
were talkin bout a 5spd or automatic?
Old Jan 29, 2012 | 05:55 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Re: Jumping Shifts
5 speed
Old Jan 29, 2012 | 06:03 PM
'84thunder's Avatar
Re: Jumping Shifts
sounds like your tranny mount may have broken. thats just by going by what you said. if the whole stick and everything is literally bouncing up. that or your braces that are right under the center console (under the car itself) are loose. start there
Old Jan 29, 2012 | 06:18 PM
Re: Jumping Shifts
Trans mount
Very easy to change out, takes longer to crawl under the car than to do the work
Cheeeeeeeep too, a stock one is like $12
Old Jan 29, 2012 | 06:27 PM
'84thunder's Avatar
Re: Jumping Shifts
make sure you get the good polyurathane mount, not the cheap one. or you will rip it apart with ur TQ. but yeah tranny mounts are easy, you dont even have to take anything off accept the old mount
Old Jan 29, 2012 | 08:15 PM
Re: Jumping Shifts
Car: 1991 Camaro RS
Engine: V6
Granted, you can tear up just about anything if you try hard enough, as evidenced by the OP's situation; but ... "necessary" is a bit of a stretch, if the OP isn't dead-set on tearing it up like his car's PO apparently was.
One thing you might run into however, is the legendary "fluid-filled" or "hydraulic" mount... it's no longer available, and if you find it, will be just STOOOPID expensive. However, its crossmember is different, and doesn't allow you to use the $12 version; but you can just get a regular one at the junkyard and do away with that, and use the regular mount.
Old Jan 30, 2012 | 09:03 AM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Re: Jumping Shifts
ok so does anyone have any pics of what to look for? and yes as soon as i hit a bump or something my **** jumps up. my brother thought it was a broken tranny. thankfully you guys said no.
Old Jan 31, 2012 | 10:31 AM
'84thunder's Avatar
Re: Jumping Shifts
this should help ya. full page from summit with a buncha tranny mounts. while ur down there (under ur car) check ur tranny crossmember. that might have come loose too. just an idea
http://www.summitracing.com/search/Y...s/?Ns=Rank|Asc
Old Feb 2, 2012 | 09:31 AM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Re: Jumping Shifts
Anyone got pics of how it looks or anyhing for some help? going to be chaning it soon
RS Reaper
Oct 17, 2018 07:52 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
