Help me identify these plugs New Ones
Car: 1989 Iroc
Engine: 383
Axle/Gears: 4th gen posi 3.73
I sent my upper aluminum tpi stuff to be polished. Between pulling them, shipping them and fininally reinstalling them it's been 4 months. I can't remember or find where they go. I also have 2 plugs the previous owner had tapped together. i don't see anyplace for them.
Passenger side of engine.
Drivers side.
Vac line looks like it goes into the bottom port on the TB.
The other end of the vac line in question goes to this canister on the front drivers side.
Just a money shot. I have the polished aluminum valve cover to install still.
Any help would be great. Can't wait to get it running again and get it dyno tuned now that I have all the mods done.
Drivers side.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help me remember/intentify these plugs
air pump diverter, coil wire connections.
Engine: Lb9
Transmission: M20
Car: 1989 Iroc
Engine: 383
Car: 1989 Iroc
Engine: 383
I got all the above figured out but I now pulled a vac line lose moving the coil wire to where it belongs.
I think I have an idea where it goes but it dosent look like it will fit. New picture what is this? It is behind the coil on passenger side firewall.
First one is wires pluged then wires unplugged and then a better shot of the vac line hook up?
Engine: 4++,350 & 305 CIs
Re: Help me intentify these plugs New Ones
Thats for your EGR. The part of it your showing is a vent for the electrical vac switch.
Someone mounted the coil on the firewall but all that is supposed to be on the pass rear 2 bolts of the intake.
Car: 1989 Iroc
Engine: 383
I love buying something older and every onwer has done something different. I still need to find the now loose vac line. Thanks.
Linson
Sep 21, 2015 01:08 PM
89 formula TPI
Sep 7, 2015 11:06 AM
