91 firebird headlight acting funny
Car: 1991 firebird bandit 2
Engine: 5.0L 305 v8
Axle/Gears: not to sure sorry new to this
Hey guys just got my 91 firebird and the drivers side light comes up most of the way but acts like it is haing a sizer or something is the motor going bad or is there some sort of ajustment i can do passenger side works fine thanks for the info (just keeps itself up half way and gose up and down quickly)
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: 91 firebird headlight acting funny
Probably not. There are 3 little plastic discs inside that eventually break up and need to be replaced. Take it apart and check. You can get them from Top-downsolutions.com.
Transmission: Pro-built 700R4
That's a super easy fix. Like Base91 said, it is the plastic bearings inside the casing that are crumbling up. It takes about a half hour and seventy-five cents to fix.
Engine: 5.0L 305 v8
sweet thanks i was wandering about replacing the plastic with metal i've heard about people rebuilding the light motors with metal gears... im sure its more than the 75 cents lol but about what would that run.. if thats the issue
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I think the kit from TDS is about $10.00. I bought 6 inches of 1/2 inch diam delrin from Tapp plastics and sliced of 7/8th inch lengths of it as replacements. Took a little bit of filing but it was very cheap. The 6 inches cost about a dollar I think.
I just went to the local Home Depot and got three ball bearings. IIRC, they were 3/4" bearings. Opened up the case, poured out the powder (which used to be the plastic bearings), put the new bearings in with some lithium grease and slapped it back together. I did the passenger's side last year and the driver's side about twelve years ago and its still working like a champ.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I like to make and fix things myself and save a few bucks here and but... If you can't be bothered then for $10 or so and a couple of mouse clicks you can sit back and wait for them to be delivered to your door step. But you could buy a couple of beers instead... It's a tough decision.
Engine: 5.0L 305 v8
i like the beer idea and do the work myself and (its all fixed)
Engine: 5.0L 305 v8
im not to much on the tech side of cars yet!!! so i told my brother in law what u all said and he fixed it for me for 20$ and sitll got me a six pack lol
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
