Timing Issues
Old Feb 1, 2012 | 03:55 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Timing Issues
If I had a intake manifold leak, would that prevent me from getting the engine timed correctly? I do have exhaust smoke coming up from the back of the engine when I first start it up. Then after a few minutes it goes away. At first I assumed it was coming from my exhaust flange on the end of the header since it wasn't tight enough
What happened is I changed my engine and now I'm trying to get it timed. But I can not get the timing notch on the balancer anywhere near the timing marks. The notch is at least 4" past the timing marks, and if I try to get it anywhere close to the timing marks the engine dies. It does take forever to get the car started, but once it does start it seems to idle fine. I don't know how it is driving though, I don't have plates for it yet. I took the balancer off too but it didn't look like it had slipped.
Old Feb 1, 2012 | 03:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Timing Issues
Where did your balancer and timing cover come from?
Old Feb 1, 2012 | 04:02 PM
Strategicsalvag's Avatar
Re: Timing Issues
Sounds like your balancer has spun. Seen it many times. Shut it off and bring it up to TDC on #1. The mark on balancer should be on 0 degrees. I bet you find it is way off from the 0 degree mark. Hope this helps. Of course it could be "other" things, but this is a relatively common problem, and would be the first thing I would look at.
-Rikki
Old Feb 1, 2012 | 04:10 PM
bigj350's Avatar
Re: Timing Issues
I don't know, it came with engine
-Rikki
Ya, I'm going to give that try, thanks
Old Jun 5, 2012 | 12:25 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
Re: Timing Issues
I cant even find the timing mark on my car... -.-
Old Jun 5, 2012 | 08:14 PM
bigj350's Avatar
Re: Timing Issues
I forgot all about this post. It did end being a spun balancer though.
Old Jun 5, 2012 | 10:16 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Re: Timing Issues
Nice! I'd imagine you got it replaced and got your timing dialed in?
Old Jun 6, 2012 | 06:52 AM
bigj350's Avatar
Re: Timing Issues
Ya I got it timed. Still got the old one on though.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
djmarch
Aug 9, 2015 05:27 PM
86Base
Aug 8, 2015 01:34 PM
