Teflon tape and Gasoline
Old Feb 4, 2012 | 08:22 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've experienced issues with an AN to fuel pump leak. An hydraulic hose shop told me that any kind of imperfection might lead to a leak and suggested Teflon tape (wrapped well away from flow). A net search led to many opinions. What's the general consensus here?
JamesC
Old Feb 4, 2012 | 08:37 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Teflon tape and Gasoline
I'd replace the fittings.
Old Feb 4, 2012 | 08:57 AM
Can't speak to the question of "consensus", whatever effect that might have on the reality; but...
The threads don't seal. The flare & seat do.
Unless you can find some way to put Teflon tape on those parts, putting it somewhere else "well away from flow" is nothing but a placebo. Might help keep threads from corroding together and seizing, but has no effect on sealing.
Old Feb 4, 2012 | 08:58 AM
JamesC's Avatar
To eliminate the problem in the short run, I threw in an Edelman 721660, which leaked as well, though not as badly. Currently, a Dorman 785-408 is in place to good effect. With both, however, the line to the carb is rubber, which I'd prefer avoiding.
JamesC
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
1992Z28!
Nov 19, 2015 07:33 AM
roysatikas
Sep 22, 2015 08:15 PM
gta892000
Sep 16, 2015 12:40 AM
