alm L98 heads on LB9
Old Feb 4, 2012 | 11:54 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
I hear mixed views on the valves not clearing the bore. I need to know asap be4 I buy them a guy wants 350 for them or should I spend it on my heads and get them worked. Not trying to hear that 350 crap please help let's end it here with facts
Old Feb 5, 2012 | 08:25 AM
ex-x-fire's Avatar
Re: alm L98 heads on LB9
You take alittle hit on compression.
Your 87 intake has a different intake bolt angle, so you'll have to grind the holes or get a different intake.
The valves should clear, they never came w/ big valves in those heads.
Old Feb 5, 2012 | 12:44 PM
Sojer's Avatar
88 vette heads and the 305 and the alm l98 heads chambers are the same size 58 cc so no lost in cr help please
Old Feb 5, 2012 | 05:51 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
The valves will clear,but at that price I'd want to see reciepts from a current rebuild.$350 is a good buy if they are fresh,but if you had to go through them,you'd be better off buying new.
Old Feb 5, 2012 | 11:27 PM
Sojer's Avatar
This has to be the best website on sbc bbc ltx lsx. What about it bolting up to my tune port and headers will it slap on I'm post to get them 2morrow
Old Feb 7, 2012 | 09:31 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
It should bolt up fine, but the lower base center bolt holes may need angled out alittle. I believe 87-up camaro/fbody stuff has 72 deg angled center bolt holes while the vettes used all 90 deg. Not a big deal, just dremel tool around the hole to oval it out.
Also, vettes dont get EGR from the head, they get it from the header tubes. So you wont beable to run EGR unless you did the vette style.
With slightly larger valve and better port design, they should flow abit more and be capable of making abit more power over stock 305 heads.
lt500r55
Sep 1, 2021 01:30 PM
CRFred
Feb 7, 2016 11:39 PM
gta90
Sep 15, 2015 04:00 PM
italiano67
Aug 31, 2015 06:04 PM
anesthes
Aug 8, 2015 09:37 PM
