Accessory Drive Kits?
Old Feb 6, 2012 | 09:42 AM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
I just about have my old engine (305 TPI) pulled out, prepping to install my 383 stroker.
I’m not really sure what way to go with power steering pump, alternator and water pump (the A/C has been removed). The power steering pump is leaking and dented, so I know I want to replace that. I found numerous pulley kits available which change the setup to a serpentine belt (and also look really cool), and I found some kits that contain the alternator, PS Pump and water pump – do they make a kit that contains everything? Or am I better off replacing each piece individually and then getting whatever pulley / bracket kit I want?
Old Feb 6, 2012 | 06:45 PM
ex-x-fire's Avatar
Re: Accessory Drive Kits?
If your short on cash, hit the junkyards for a serpitine belt set up. Try to find a complete system, you might even use parts off of a 4.3L v6.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Terrell351
Jun 13, 2021 01:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
toronto formula
Nov 10, 2015 06:17 AM
fasteddi
Sep 2, 2015 10:29 AM
