More VATS insanity!
Old Feb 10, 2012 | 12:14 PM
orpack66's Avatar
Car: 1989 Camaro RS
Engine: 5.0L TBI
More VATS insanity!
Hey, campers...
Back in October '11 I got some good advice on this board re: VATS issue. Nutshell: intermittent & maddening no-start, no-crank, no-noise, no-security light, no-nothing condition.
Consensus fix was to bypass VATS with a resistor equivalent to the resistor in the ignition key. No sweat operation...and while doing it I discovered that the bypass had been done by a previous owner, albeit poorly - sloppy connections and marginal resistor value. Whoo hoo...my new repair would surely solve the problem! And it did. Flawless operation.
Until about 6 weeks ago...when - yes - I went to start 'er up and got nothing but the maddening no-start, no-crank, no-noise, no-security light, no-nothing condition. The condition has continued to manifest itself at shorter intervals since.
I do notice that when the failure is imminent, there is a very slight delay between turning the key and starter engage. "Turn - hic - vroom". There will sometimes be a slightly longer delay: "Turn - hmmm - vroom". Hic is about 1/4 sec; hmmm is about 3/8 sec.
I am going to re-do the resistor fix shortly; any ideas on what else I might do while I'm in there?
There is an aftermarket alarm in there (Auto Mate AM-5), but it doesn't appear to be involved in any ignition circuitry.
Thanks!
Old Feb 10, 2012 | 10:55 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: More VATS insanity!
I had an ecm that when it went bad began to act "funny" like that. You could try another ecm if the resistor does not fix it. Or perhaps see about a chip with the VATS flag turned off.
Old Feb 11, 2012 | 04:43 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by orpack66
I do notice that when the failure is imminent, there is a very slight delay between turning the key and starter engage. "Turn - hic - vroom". There will sometimes be a slightly longer delay: "Turn - hmmm - vroom". Hic is about 1/4 sec; hmmm is about 3/8 sec.!
Maybe the starter relay is on the way out and not making a good contact every time
Old Feb 11, 2012 | 06:29 AM
orpack66's Avatar
Car: 1989 Camaro RS
Engine: 5.0L TBI
OK...now I have two worthy suggestions to follow up on. Keep 'em coming!
Thanks!
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
customblackbird
Oct 1, 2015 04:30 PM
AmorgetRS
Sep 28, 2015 09:33 PM
Winchester1094
Sep 15, 2015 09:48 AM
