Need help with picking heads???
Old Feb 11, 2012 | 07:13 PM
sheik yerbooty's Avatar
I am a old school guy,so the newer engines are not what I am familiar with. I have a 55 chevy, with a .60 over 283. It has been built to a dz 302 engine spec. The heads are to the point of being non usable.So the question is alot of people are telling me to go with late 80's 4 barrel 305 heads with 55cc chambers and the 1.8 int 1.5 exh valves. The question is is the 601 head the best head for the small c.i.d. I am running?
Old Feb 11, 2012 | 07:38 PM
ex-x-fire's Avatar
Re: Need help with picking heads???
350 vortec heads are much better then any stock castings, they have fast burn chambers & excellent midlift flow, which means the peak air flows occurs at the opening & closing of the valves. You'll need a vortec intake for those heads. I think the heads measure at 64 cc.
302 chevvys have 4" bores so any head for a 350 should clear.
Old Feb 13, 2012 | 08:54 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
ah,but 283s dont have a 4in bore,id try a set of ported "416"s
Old Feb 13, 2012 | 09:14 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I would second that thought. Many members on these boards have done well with them. do a search for the 416 head. I even own a pair, ported with new springs and valves. Never used them though.
Old Feb 14, 2012 | 12:52 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Another option - 305 ci "059" Vortec heads. They're not as spectacular as the L31 Vortecs, but many have done well with them.
Here's some info:
http://www.hotrodders.com/forum/vort...-a-125625.html
Old Feb 18, 2012 | 04:09 PM
t.c.815's Avatar
Sheik, pick up a pair of Vette heads 113 casting, they are58cc chambers, if your capable of porting have at it they will flow as good as the vortec"" and you wont need a vortec manifold, they will work with that 4" bore, Terry
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
