Lost chip from key
Lost chip from key
Hello, I have a 1990 Camaro IROCZ, somehow the chip fail out of the ignition key. I went to a dealership and they say they don't have the codes going back that far. Does anyone know if there is away to completely bypass the VATS system, without the chip in the key? The chip is lost. Thanks in advance for all ideas and help
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Lost chip from key
There are a couple ways to bypass the vats. you can buy a cats bypass module ebay or painless wiring. you can have the vats reprogramed out of the memcal or buy some resisters and try them until you find the match of the passkey module.
https://www.thirdgen.org/vats_passkey_system
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I had to have a new VATS module programed to a new key.I tested the pellet in the new key for resistance ,then filed the results in my Camaro file. I ended up using that resistance in a VATS by pass of my own creation.
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
I need to buy a spare VATS key for my 89 IROC-Z. I've seen them advertised online at about half the price of one from the dealer. I asked the seller how he would determine which resistance pellet was required and he said that he or the dealer could look it up through my VIN number. I know there are about 15 different resistances used so is this accurate? Or can the dealer still check my key and tell me which one I need?
Engine: Lb9
Transmission: M20
Engine: 305 TBI
Engine: 4++,350 & 305 CIs
I had my dealer get the key and vats code for my 89 formula. If they tell you they cant do it They are just lazy.
Engine: 305 TBI
use your ohm meter and find the corresponding number off the chart on this link.
Engine: 305 TBI
Engine: 305 TBI
Thanks again!
