Tell me it's NOT the starter! 92 RS
Old Feb 13, 2012 | 03:28 PM
Inlovewithan83's Avatar
Okay, so sometimes when I start my car it makes that noise cars make when you go to start it and the car is already started, and it will do this for one, two or three cranks and then the car comes starts.
Is that the starter going on me?
Old Feb 13, 2012 | 04:15 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Tell me it's NOT the starter! 92 RS
Most likely
Old Feb 13, 2012 | 04:54 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
or bad teeth on your flywheel. It's a couple wires and two bolts to pull the starter, pull it out and take a look
Old Feb 13, 2012 | 05:15 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
don't forget to disconnect the battery first. That Light and spark show can be unnerving when you're in close proximity to it.
Old Feb 13, 2012 | 05:47 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
yup, rule #1 when working on ANY vehicle
Old Feb 13, 2012 | 08:32 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
I will tell you it's NOT the starter but in reality it is :/
Old Feb 13, 2012 | 09:38 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Be glad it's the starter. It's one of the cheaper simpler repairs you can make.
I'd buy a used one or a cheap ebay LT1 starter. They're chinese and unreliable, sure, but I dont think the reman LT1 starters are much better than the ebay LT1 starters that cost 1/3 as much.
Otherwise there should be some GM starters on craigslist somewhere for $15 if you really want to be cheap.
Old Feb 13, 2012 | 10:19 PM
Richboll's Avatar
Engine: 305 TBI
Here you go. Starters starting (get it?) at 37 bucks from OReilly's
http://www.oreillyauto.com/site/c/se...eyword=starter
Just remember to tip it to get it out.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
