What was your winter project / how is it going?
Old Feb 15, 2012 | 06:59 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Just curious who else was in the process of a winter project on their cars?
This forum needs a "Lounge" type of sub forum - didnt really know where to post this....
Old Feb 15, 2012 | 07:17 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: What was your winter project / how is it going?
I am finishing my 454 install and when it warms up a little I will be rebuilding the trans in the z
Old Feb 15, 2012 | 07:25 PM
insomniac's Avatar
Engine: 5.7 L98
how low does the car sit in the front with that much motor in it?
Old Feb 15, 2012 | 07:43 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
deleting my ac, and putting in ac delete box, installing new injectors, and finally putting in my overhead console.....so far I haven't got much done lol I've been slacking
Old Feb 15, 2012 | 08:28 PM
Edwardgp's Avatar
Engine: 454-350
It sits three inches higher than stock I rebuilt the front end and install high lift springs. Not to worried about the cornering.
Old Feb 15, 2012 | 08:31 PM
82CAMAROBBC's Avatar
Car: 1982 Camaro
Engine: 454
Transmission: TH350
Axle/Gears: 410
New paint and oem notchback
http://www.facebook.com/media/set/?s...1&l=15c0ef3ed1
Old Feb 16, 2012 | 10:18 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not really. A lounge forum was tried a few years ago, and was a disaster. The racing forum usually has a "winter project" thread, as people tend to do maintenance/upgrades during the winter in prep for the next season. As long as the responses here are tech related, this is fine.
Personally, the only thing I had planned, other than the usual fluid changes and general check-over, is to remove the headers from the LS1/4L60E Berlinetta and send them off for ceramic coating. I won a free coating job from the NHRA "Be a Member/Be a Winner" drawing from the 2011 season.
That project hasn't gotten started yet because my son has his 2001 S10 Blazer with iron block 5.7 LS swap in the garage for rear end upgrades (from stock centrifical posi to Eaton, 3.42 gears to 4.11, and traction bars), intake change from LS1 to BBK (it has an unknown but pretty lumpity cam, and the LS1 intake was holding back peak power), and replacement of the valve stem seals (it was using quite a bit of oil, even though a fresh build, and there was oil sitting on top of the intake valves when he pulled the LS1 intake). His project has hit several snags, like parts not showing up when they are supposed to, so until we get that finished up, mine can't start.
Old Feb 16, 2012 | 12:24 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
Almost a total rebuild of the Camaro I (finally) bought in July. Totally re-did the entire entire including a custom build sub box and a custom T-Top holder in the back. In the process of pulling the stock 305 TPI and replacing with a 383 with the HSR setup. Engine is coming out Saturday, new one going in...once I get everything I need for it
Old Feb 16, 2012 | 01:08 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Mine is down for lt4 hotcam and porting heads. Also bought a steering wheel and some founders lca aphb and lca relocation brackets.
Still need shocks springs and a torque arm. Thinking about the panhard relocation kit. can't wait till spring
tmellott89
Oct 14, 2015 02:06 PM
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
