400 HP out of a 5.7
Old Feb 20, 2012 | 02:54 PM
mijares's Avatar
400 HP out of a 5.7
i have an 87 camaro iroc manual transmission does anyone have suggestions on how to get 400hp out of it its a 350 5.7 engine
Old Feb 20, 2012 | 04:16 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: How much horsepower can i get?
You can make 400hp with a 305 and a carb, but it will be making the power somewhere north of 6,000rpm and need a perfect match of heads, cam, intake, timing, and exhaust. I'm making about 400hp with my 350 at around 5600rpm, a 305 would have to rev 15% more for the 15% decrease in cubic inches - about 6450rpm, way too high for a stock 305 - but not too high for a built bottom end.
Old Feb 20, 2012 | 05:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
mijares, welcome aboard thirdgen.org.
Paul's response probably looks a little weird, because I moved your post out of the "how to get 400 HP out of a 305" thread where you posted it, to it's own thread. I moved it because we try to keep each thread on a single topic.
So, how do you get 400 HP out of a 5.7? Depends upon how you're measuring that HP. Gross flywheel HP, not too hard. Rear wheel HP, a lot more difficult.
But, 400 GFWHP is a piece of cake - swap in an LS1...
Okay, assuming a "normal" Gen I 350 - Vortec heads, Comp XE268 cam, Performer RPM intake, 650 Holley double pumper carb, 1-5/8" primary tube headers and free flowing exhaust.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
KO1
16
Oct 15, 2015 05:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
usafirebird
Sep 29, 2015 11:58 PM
IROCtometal
Sep 9, 2015 10:01 AM
