needs to place order tonight!
Old Feb 21, 2012 | 04:19 PM
Regal105's Avatar
Car: 83 c10, 2015 silverado
Engine: 454, 5.3
Transmission: Turbo 35o, 6l80
Axle/Gears: 3.42, 3:23
ready to but the cam for my 400 and im just a couple clicks away form buying a comp cams extreme energy xe256h .447"- .454" 256 - 268 1000 - 5200rpm and im just wondering if i can use stock valve springs with this cam
i dont have heads picked yet but im wondering generally if stock heads can handle this much lift thanks!
Old Feb 21, 2012 | 06:18 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: needs to place order tonight!
447/454? Yes
Old Feb 22, 2012 | 06:33 AM
No you cannot use stock springs with an aggressive aftermarket cam like that...
There's more to what makes a spring work or not work, than just the peak lift #. Problem with stock springs is, nowhere near enough tension to control the motion of hte valve and keep it from bouncing off of everything as it gets slubg wildly around by those STEEP lobes.
Yes stock heads can usually accomdate that much lift however.
Old Feb 22, 2012 | 08:32 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Isn't that a really small cam for a 400?
Bubbajones_ya
Jul 6, 2024 08:32 PM
1MeanZ
Dec 18, 2015 05:39 AM
Scorched1984
Sep 15, 2015 03:42 PM
webeeZ28
Sep 14, 2015 12:00 PM
scottmoyer
Sep 7, 2015 07:06 PM
