View Poll Results: Should I keep my A/C or remove it?
Keep A/C, it gets too hot to go without it in the summer
66.67%
Take it out, that's why you have T-tops...
33.33%
Voters: 21. You may not vote on this poll
A/C, keep it or remove it?
Old Feb 15, 2012 | 11:12 AM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
So I've got my interior squared away, as well as a couple thousand dollars in suspension and brakes. Now I'm to the engine. I'm going to pull the stock L-98 out and repaint the engine compartment and run the wiring harness nice and neat. I also plan on adding some polished aluminum parts and will be cleaning up the corvette L-98 I picked up.
I'm just up in the air about the A/C. My car is not a daily driver but its gets driven quite a bit on pretty days. So having air is nice, although it would look cleaner under the hood without it. If I take it out I will keep everything in case I want to put it back in. My main thing is I hate all that clutter on the passenger side with the A/C compressor and lines. Thoughts on this? Who has taken their A/C out and regretted it? Who doesn't regret it?
I just need some opinions to help me make up my mind on this.
Old Feb 15, 2012 | 11:15 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: A/C, keep it or remove it?
I disconnected mine, have driven the car twice, and already want it back. It's getting reconnected as soon as I build new lines for it
Old Feb 15, 2012 | 01:00 PM
91CamaroRS/SS's Avatar
Well on mine even on the original motor, my a.c never worked. So after the motor swap I just gutted the entire setup for a.c and I love the extra room I have to do what I want with it. Plus if you have t-tops/convertible who needs a.c. Just a waste of 3-4 HP. On those brutal summer days, I ride the motorcycle. Moral of the story: get a motorcycle
Old Feb 15, 2012 | 01:14 PM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
keep the ac i love my ac would not take it out for anything
Old Feb 15, 2012 | 01:38 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
the real question, is where do you live?
Old Feb 15, 2012 | 06:10 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
I would keep it in. unless your a track car or you really really need the extra room. and don't really drive it in traffic or streets much.
Old Feb 15, 2012 | 06:49 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
I have to agree; keep it.
My 81 TA had no ac/ and in the summer (NC) it was brutal. The PO cut out the lines and got rid of everything, leaving me with a very screwed up mess.
As previously mentioned, unless you want it to be a track car, or if you live somewhere that it doesnt usually get very hot and you feel that T-Tops and the windows down will suffice, sure. Take the A/C out. But I for one think youll regret it shortly afterwards.
Just not worth the hassle and loss of ac.
Old Feb 20, 2012 | 11:04 AM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
I've posted basically the same in the Midwest forum as I'm basically in the same situation. Seems like it would be convenient to me to get rid of it and not have the clutter, plus I drove mine all last summer without the AC functioning and the HVAC flap stuck in the heat setting anyway. As I noted, my concern is how to defog the windows when it's raining as I had that trouble last summer.
Old Feb 20, 2012 | 11:42 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
I've had my Camaro since 05' and I've used ac the first summer. After that I never realty used it even in 90* days. Now I pulled my ac stuff out and I do not miss it. But if the ac worked better I might have kept it.
Old Feb 20, 2012 | 11:43 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Keep the AC. I was finally able to reinstall everything on my car and I love it. Too blame hot without it. It doesnt take up that much room. I dont see why that is ever a good enough reason to remove it. Seriously, what does it block? What does it make it harder to do with it there?
Keep it.
Old Feb 20, 2012 | 05:35 PM
ahankins32984's Avatar
Car: 1986 Camaro Z28
Engine: 5.0 305 TPI
Axle/Gears: posi 3.73
My z28 has t-tops and of course when I bought it the A/C components had already been removed so I am bias of hard top vs. t-top!!! But I agree with most T-top owners that's the main reason they're there to remove and not need the A/C the t-tops are better at circulating the air anyways!!!!
Old Feb 20, 2012 | 06:51 PM
3rdgenmaro's Avatar
Car: 88 IROC
Not when you are sitting in traffic or at a long stoplight.
I love T-tops too, but they arent just as good. What about a hot day during a rain? I dont want windows down or t-tops off and it gets awful muggy without A/C.
Old Feb 20, 2012 | 07:03 PM
Engine: 5.0 305 TPI
Rainy hot humid days are the only uncomfortable days when it comes to t-tops I can agree!!!
Old Feb 21, 2012 | 12:27 AM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
I live in East Tennessee so it get's pretty darn hot in the summer, humid as well. So I think I've made up my mind and have decided to keep it. Especially since the car only gets driven on nice, sunny days. And I don't think my girl would appreciate riding around in a steaming hot car. lol... I'd just hate to remove everything then regret it. And I only take the tops out when cruising through the mountains anyway. Up there you don't need A/C, but down in the valley it gets a little too toasty.
Old Feb 21, 2012 | 03:37 AM
branndooo's Avatar
Car: 1991 Z28 Camaro
Engine: 350 TPI worked
Transmission: ziggys race tranny 700+hp
Axle/Gears: Trying to figure out plz help!
i need help getting mine back in. i bought my car completely stripped ac heat wipers. im trying to put it all back in any help would be greatly appreciated.
Old Feb 21, 2012 | 07:35 AM
3rdgenmaro's Avatar
Car: 88 IROC
do a search.
then when you are stumped, start your own thread and give a ton of details on what you have, and what you are wondering.
Old Feb 22, 2012 | 01:12 AM
branndooo's Avatar
i dont think i can make a thread yet i just signed up. i not to good with the site ethier but thank you i been searching a lot.
Originally Posted by 3rdgenmaro
do a search.
Old Feb 22, 2012 | 07:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Perhaps because I'm an old fart, I enjoy creature comforts far too much to go without AC, especially in Kansas heat. Keep it.
JamesC
Old Feb 22, 2012 | 08:41 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
For a driver, def keep it. I've been meaning to rebuild mine for years now, but other stuff always seems to keep coming up first. Some po made off with my compressor and lines.
Really need it in the Sydney heat here too, but have done with just windows for years. At least summer seems to have been a no-start this year... alas my fart is getter older too...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Ironhead38
Sep 7, 2015 02:26 PM
85Special
Sep 3, 2015 04:21 PM
