383 Mini Ram vs head issues
Old Feb 23, 2012 | 12:05 PM
WHITE87GTA's Avatar
Hi I have a 383 short block all set to go. I have a used mini ram intake complete with fuel rail, 1000cfm throttle body and 42lb injectors. I have narrowed down my choice of heads to a set of 195 profilers or the new dart shp as i have some budget restraints.Cam selection is 280xfi. chip tunning will not be a issue. The issue is i found out that the mini ram i have is a 1206 and the heads that i am interested are a 1205.
If i port match the heads to fit a 1206 what will the effects be.
If i do not port match what will effects be?
Also will the 42 lb injectors be to large?
Does any one make a 1206 head in the 190 to 200 for budgets?
i really want to keep this intake and i know if i had the extra cash a set of AFR195 comps are 1206 and all would be good but i do not have that in budget.
Frozer!!!
Jan 19, 2024 04:55 PM
Wesly_66
Aug 26, 2015 09:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
