loud screeching coming from bottom of engine...
Old Feb 24, 2012 | 10:16 AM
dornewass's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: stock
so i have a 91 rs 305 tbi. after sitting for wuite some time, i finally got it started again. i recently put in a new starter, and have not gotten it to start. so i put in a push button just to jump the starter to get it started. but now it's making a very loud screeching noise coming from the starter/oil pan area. i don't think it's the starter staying engaged, i looked at it while it was running. and i am completely stumped....
recently installed/modded:
stock starter
remote solenoid
push button switch (to start it)
vats bypass
Old Feb 24, 2012 | 10:30 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: loud screeching coming from bottom of engine...
stock starter
remote solenoid
vats bypass
Did this problem just start after you installed the new starter?
Old Feb 24, 2012 | 10:50 AM
dornewass's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: stock
yep. but it also hadn't run for probably close to 6 months or so.
Old Feb 24, 2012 | 10:55 AM
ninetyone's Avatar
Axle/Gears: 3:42
did you shim the starter? Could be a bad starter too
Old Feb 24, 2012 | 11:18 AM
dornewass's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: stock
starter is shimmed, and i know the starter is good, had it tested.
Old Feb 28, 2012 | 04:28 PM
dornewass's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: stock
any other ideas?
pimp2303
Jul 27, 2017 02:03 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
db057
Aug 22, 2015 08:17 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
