Quick Question
Old Feb 24, 2012 | 07:41 PM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
Quick Question
Ok so im learning to burn out, so this is my question. i got a standard 1991 camaro rs v6. do i hold clutch in and rev it to about 4k and then let it go? and then hold the break. the brakes work in the back wheels and front no?? or what?? im confused??? sorry for amateur question
Old Feb 24, 2012 | 07:58 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Quick Question
The engine can outpower the brakes.
Old Feb 24, 2012 | 08:09 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Quick Question
On my ride I use a line lock and it is great for getting the meats hot and sticky. It locks up the front brakes while releasing the rear.
Old Feb 24, 2012 | 08:36 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Re: Quick Question
line lock? never heard of them. ok so lets say i do and try to burn out, this will wear out my rear breaks wont it? i thought the breaks were only in the front.
Old Feb 24, 2012 | 09:13 PM
Car: 1992 Camaro RS
Re: Quick Question
A line lock is a device that's pretty much only used by drag racers specifically to do burnouts. Uses a special setup that you splice into the brake system hydraulics and it basically makes the front brakes lock up and doesnt affect the rear brakes at all. It's nice, but unnecessary for most of us regular guys. If you spend a lot of time racing at the track it's a good idea to have one though.
http://www.summitracing.com/parts/SLE-24048/
You'll wear out your tires more than your brakes doing burnouts. You have brakes on each tire.
Old Feb 24, 2012 | 09:14 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Quick Question
Even in a V6, dropping the clutch often is a good way to ruin the transmission and rear end. A line lock is something that would clamp the front calipers only, allowing the rears to still spin freely. If you are just driving around trying to spin your tires, you're just begging for a ticket.
Old Feb 24, 2012 | 10:13 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
Axle/Gears: 3.23 10 bolt limited slip
Re: Quick Question
Go to the mall and find an open side of the parking lot around 8pm. Cut the wheel hard to the left and floor it. Then after about 2 circles turn hard right and repeat. Then immediatly get the hell outta there before the fuzz come. Try this a few times and you'll be a pro by the end of the night.
LOL just kidding
Be careful on the street though. The rear end will kick out and you'll lose it if you go too fast around a corner. Please don't kill yourself.
Old Feb 25, 2012 | 10:10 AM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Re: Quick Question
ok i see. no i dont want to do it often but my friend thinks his honda accord can burn my car out so i want to show him how my car has all the skills to pay the bills, because its impossible to break and harder to kill.
Old Feb 25, 2012 | 10:13 AM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Re: Quick Question
so when burning out i set it at 2nd gear wrong?? because i would think 1st but ive seen people on 2nd??
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
