1991 firebird shift light
Car: 1991 firebird bandit 2
Engine: 5.0L 305 v8
Axle/Gears: not to sure sorry new to this
Ok i took out the center console to get to the little light under the shifter to light up the window that shows what gear im in.. the ? is how do i get that little light out of the socket to replace it and what am i looking for to buy a new one. part name or number would help thanks
Car: 1991 formula firebird
Engine: 5.0
Transmission: automatic
Re: 1991 firebird shift light
i may need that info. as well, when i bought mine the wire had been cut and don't know where it hooks back up to, anyone with that info?
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
https://www.thirdgen.org/forums/tech...indicator.html
There you guys go i just did mine! Sylvania Mini bulb part number # 74LL available at autozone. Mine was just snapped in like a connector, it popped right out. Its a very small small bulb inside.
Blackpaint- not sure about cut wires as mine was connected. Check to see if they were split for some reason & reconnect.
heres what mine looked like. I really like it.
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
dhonda200
Aug 11, 2015 11:50 PM
