Problem with throttle response
Old Mar 5, 2012 | 07:39 PM
goosehunter87's Avatar
Car: 82 TransAm (45,000 original miles)
Engine: 305 TBI Cross-Fire
Transmission: 3 speed automatic
The last month or two I have noticed rather poor throttle response, but only at times. The engine had power to spare but it would have a delay, jump and continue to have a choppy acceleration. At times there was no problem and it would accelerate perfectly smooth. I replaced spark plugs and it helped but it doesn't feel like a misfire. Today I went to start it just after I got home. The engine was warm as it had ran for about 20 minutes about a half hour earlier. It started easily and ran for a few seconds then died. I started it again and it had such low rpm that i had to press the gas slightly to keep it running. It wanted to die if I let off. The fuel filter is literally non existent earlier this month I jacked the car up and followed the fuel lines straight to the engine. No filter anywhere, I even asked my mechanic and he lifted it and couldn't find one. Anyways as far as I know it still runs but what is the problem any ideas?
Old Mar 5, 2012 | 08:25 PM
Damon's Avatar
Re: Problem with throttle response
Fuel filter is in the nose of the carb. Right behind the big nut that the fuel line fitting screws into.
Old Mar 5, 2012 | 08:32 PM
I have the cross-fire injection system not a carb. If anyone with this setup could direct me to the fuel filter that would be great.
Old Mar 5, 2012 | 08:38 PM
Or if you have any other ideas on what the problem could be let me know.
Old Mar 6, 2012 | 12:52 AM
Chainlynk's Avatar
I had the same problem with my 86 trans am. They have a filter on the fuel pick up in the tank. The breather on my gas tank clogged up and it pulled the filter over the fuel line so it would only pull fuel through one small spot which quickly got very dirty and wouldn't let much fuel through. I had noticed that when I took my gas cap off it would suck a lot of air as soon as I cracked it. Anyway I put a new breather on, dropped the tank cut the filter off and put an inline filter on it, no problems since.
Old Mar 6, 2012 | 02:18 AM
lectric80's Avatar
Car: 83 Z28 T-top
Engine: 350 carb'd
The fuel filter should be located on the driver's side frame rail just forward of the LCA. The fuel pumps were known to grow weak over time, so if the pump hasn't been replaced recently it may be worth looking at.
Old Mar 6, 2012 | 06:33 AM
ex-x-fire's Avatar
Check the fuel pressure, should be 9-12 psi.
Old Mar 6, 2012 | 12:03 PM
The fuel filter is surely not in-line. Nowhere to be found along any part of the frame all the way from the tank to the engine bay. I found a site that talked about 2 of them located under 1 inch fittings on the throttle body. I found what I believed to be them and cleaned them up with a solvent. It helped a fairly decent amount and really livened up the engine but I still have yet to fix the throttle response issue. I can assume it is the fuel pump. How much time should I expect to invest to drop the fuel tank and do the replacement?
92camaroJoe
Jul 29, 2023 07:57 PM
db057
Sep 4, 2015 07:57 AM
perZ
Aug 15, 2015 01:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Fronzizzle
Aug 9, 2015 01:15 PM
