1984 Z28 305 Timing Specs
Old Mar 9, 2012 | 09:40 AM
GnawgaHyde's Avatar
Car: 1984 Z28
Transmission: 5 speed
Axle/Gears: Stock
hey fellas. can anyone give me the specs for the timing on a 84 305 carb engine. I changed out the intake and the manifold only to find I need to also change out the Distributor with a vac Advanced one. I would assume that 6 degrees before TDC at idle with the vac unhooked. can anyone tell me more so I can get this right the first time? The MSD street fighter I bought has adjustable vac advance. Just need more knowledge.
Old Mar 9, 2012 | 09:37 PM
Damon's Avatar
Re: 1984 Z28 305 Timing Specs
If you've ditched the computer controlled carb and distributor you're back to an "old school" type engine. Which means old school timing specs. 10-12* initial to get you in the ballpark. That's with the vacuum advance disconnected and the idle at it's lowest RPM so you aren't kicking in the centrifugal advance at all while setting the base timing.
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
