too much fuel pressure?
Old Mar 13, 2012 | 06:30 PM
Racca116's Avatar
Car: '85 Camaro Z28
Engine: 355 carburated
Transmission: TKO600
Axle/Gears: GTA rear, 3.73 posi, hotchkiss
im running a edelbrock 1407 carb (750cfm) on my 350. the paperwork says not to run more than 6.5 PSI fuel pressure. i have a 80gph @ max 8 psi pump i wanna put on. it seems like the carb should be able to handle that. is the paperwork just covering edelbrocks *** or do i really need to run a regulator on such a mild pump?
Old Mar 13, 2012 | 06:46 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: too much fuel pressure?
That is what they have rated their carb at;
higher pressures on that carb may hold the needle off it's seat leading to flooding and poss fires
Old Mar 13, 2012 | 06:56 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
You don't want to go over 7psi on any carb, 5.5-6psi is ideal otherwise you start having fuel coming out of the carb and leaking out of gaskets, screw holes, everywhere. There's a reason they list the PSI rating.
Even with the 8PSI pump, you'll want to run a regulator to keep it 6.5 PSI or less.
Old Mar 13, 2012 | 07:03 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Why would you want 80lbs. with a carb??? How is your insurance.
Old Mar 13, 2012 | 08:25 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by Edwardgp
Why would you want 80lbs..
Pump is rated 80 gallons per hour at 8 psi
Old Mar 14, 2012 | 02:54 AM
Racca116's Avatar
Car: '85 Camaro Z28
thanks guys, can anyone suggest a good reasonably prices regulator?
Old Mar 14, 2012 | 03:09 AM
Racca116's Avatar
Car: '85 Camaro Z28
also do you think its even worth installing? how much differenace should i feel over the stock one
Old Mar 14, 2012 | 12:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Mallory 4309.
If your stock pump doesn't have trouble keeping up with the needs of your engine, there's no benefit to be had from changing it.
Old Mar 14, 2012 | 02:07 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
7.5 PSI is the most that any of my Edelbrock carbs can handle, and I have a bunch of them.
Anything after that and they will flood intermittently, depending on conditions, slope, vibration, g-forces, etc...
There are ways to make them handle more pressure, but it's a lot of trouble.
Old Mar 14, 2012 | 02:25 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I think the OP's question may have been "will the larger carb make a difference in his performance?" That depends on what mods have been done to the motor. On a stock motor, a larger carb will have little effect as it's the heads, cam and intake that really determine performance. If your car has high miles and the carb is worn and in need of an expensive overhaul, you may choose to go with something different. The CCC carbs can be difficult to set up if you don't understand the system or have the correct equipment. If the carb is badly worn(throttle shaft bushings) it may be impossible to tune correctly without having the bushings replaced.
Old Mar 14, 2012 | 02:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I don't see anything about a larger carb?
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
