Timing issue...need help
Old Mar 14, 2012 | 09:19 AM
Igorealfast's Avatar
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
Here's my issue. Did my engine build, I do not have a knock sensor, and the new chip turned the sensor off. So with the stock distributor I have a serious detonation problem (comp 11:1). Am replacing my stock distributor with a new mechanical advance distributor/MSD-6AL. Hence bypassing the computer for Ignition. I am running a stealth Ram. Question....How do I, or what is necessary to make sure my injectors are getting a signal from the computer/ mechanical distributor? Chew on that one fellas....
Thank you,
Brad
Old Mar 14, 2012 | 09:45 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Timing issue...need help
your leaving out a lot, what ecm are you trying to run? mega squirt ?
Old Mar 14, 2012 | 10:11 AM
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
Stock GM Computer. My guess is there is a way to use the magnetic pickup in the distributor to send a signal to the ECM.
Old Mar 14, 2012 | 10:22 AM
Engine: Lb9
Transmission: M20
I do not believe you will have enough room to run a second pickup just to give the ecm a pulse reference to control the injectors. I think your money would be well spent going to dynamic efi ebl p4 and junk the maf. You could always remap your spark tables.
Old Mar 14, 2012 | 12:14 PM
ironmansed's Avatar
Car: 92 camaro rs
Engine: 350 h/o
i have a 350 h.0.. do i need to change the chip to get a lil more power
Old Mar 15, 2012 | 05:58 AM
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
among other things yes. Simple things to make more power, headers, having a chip burned for your modifications is always a good idea. The big limit on TPI cars is the TBI doesn't really allow the car to make much or any power past 4800 rpm. So a different induction system will really wake your motor up.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
