Removing battery resets IAC? (car dies on idle)
Old Mar 14, 2012 | 10:41 AM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
I had to remove my battery last night and put it on charge and when I put it back in this morning the car would start but die immediately unless I gave it gas, basically it would die as soon as it idles but will run fine when actually driving. The car ran perfectly on idle before I took the battery out so I don't think it could be leaks in the vacuum hose or bad fuel injectors. I did read about on another thread that if you take the battery out it resets the IAC computer and you have to drive the car around for a while and then park it to reprogram the computer, is that true? another thing I did was take the fuse out for the fuel injectors and I'm not sure if it blew but even if it did I have no idea if it could cause this problem.
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
3rdgenparts
Aug 8, 2015 07:09 PM
