87 Iroc stalling out. Need a little advice.
Old Mar 14, 2012 | 01:16 PM
ironreaper87's Avatar
Car: 1987 IROC Z28 Camaro
Engine: HSR L98
Axle/Gears: stock
Well the darn thing stalls out every once in awhile whenever I put it into a gear such as reverse or drive. I checked the voltage on the TPS and it was around .5
Should I swap in another TPS?
And another thing...it only seems to do this when its hot. Today is the first day of real heat around here..so I took it for a little drive and I stalled 4 times trying to get out of a gas station
Could that mean MAF maybe or intake heat?
Old Mar 18, 2012 | 12:33 PM
DanzigEx's Avatar
Car: 1986 Z28
Engine: 305 LG4
Transmission: TH700R-4
Re: 87 Iroc stalling out. Need a little advice.
Here's some suggestions: http://wiki.answers.com/Q/Why_would_..._stall_in_gear
Best I got so far.
Old Mar 18, 2012 | 02:42 PM
Engine: HSR L98
Axle/Gears: stock
Best I got so far.
Well I bought a new TPS.
I hooked 3 leads up and started measuring voltage. I had it set on .5v
BUT
After it cranks and gets into idle it starts reading this.
.5
.49
.47
.46
.44
and so on until it gets low enough that it stalls. So I am replacing everything that deals with the TPS including the wiring.
Old Mar 19, 2012 | 11:00 AM
Willishxc's Avatar
Car: 1985 Iroc-z Camaro
Engine: 350 V8
Hey, my cars doing pretty much the same thing i believe. It wasnt running at all and my dad and I switched out all the spark plugs and turned the distributor up and it was running fine. Drove it to school today though and whenever i'd come to a complete stop the rpms would slowly drop and eventually stall out then have trouble restarting.
We were thinking first to put a new distributor cap on, but your ideas sound good to, we're also going to check the rest of the timing and if the fuels running too lean. Let us know how your fixes go! Any help you get might carry over to mine.
Good luck!
Old Mar 19, 2012 | 02:20 PM
davidjr74's Avatar
Car: 1985 Camaro Iroc
Engine: 350 tpi
Vacumn leaks?
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
Bryan F
Aug 18, 2015 02:28 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
