rear main seal gaskets question
Old Mar 18, 2012 | 08:58 PM
Z06 FAN's Avatar
Car: 87 Iroc
Engine: built 355, 450HP
Transmission: built 700r4
I removed my engine a couple of months ago and am now in the process of putting things back together. The problem is i don't know where the one complete circular gasket goes. This would be the one that has like 9 bolts that go thru it and has a flat side on it? Anyone know where this gasket goes??
Old Mar 18, 2012 | 09:15 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: rear main seal gaskets question
kinda sounds like the front timing chain cover gasket? ????? just guessing.
Old Mar 18, 2012 | 09:21 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
sounds about right for bolt holes but arent most of them u shaped?
Old Mar 18, 2012 | 09:25 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
yes, was just guessing. a pic would help for sure. lol.
Old Mar 18, 2012 | 09:47 PM
Z06 FAN's Avatar
Car: 87 Iroc
sorry, its a one piece rear main seal kit and it comes with two gaskets. sorry cant get any pics till morning.
Old Mar 18, 2012 | 11:15 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Z06 FAN
sorry, its a one piece rear main seal kit and it comes with two gaskets. .
forget about it
the only gasket at rear is the 1/2 circle one between the seal adapter and block
Old Mar 19, 2012 | 06:18 AM
Z06 FAN's Avatar
Car: 87 Iroc
Ok thanks, thats what I thought. Its the only gasket I remember seeing when it came apart a couple months ago!
Old Mar 19, 2012 | 07:12 AM
84redta's Avatar
If I remember correctly, when I got the kit for my car, I had a v6 one and a v8 one in the same kit.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reborn756
Sep 4, 2015 03:42 AM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
