no idea where i shoulda put this but
Old Mar 21, 2012 | 01:58 AM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
mine windsheild washer doesn't work, everything is hooked up (now) and i have fluid i hit the little tab to make it spray but nothing, my wipers move and everything but its like the lines are clogged or the pump isn't working i swear its all hooked up right as far as i know and the lines are all like new, full fluid just doesn't work, not a serious issue, just something i'd like to fix anyone?
Old Mar 21, 2012 | 06:35 AM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: no idea where i shoulda put this but
If you just replaced the lines, you will need to prime it to get it to work the first time. I used one of those injector things from the kitchen. Looks like a really big syringe. Put some water in it and force it through the line from the reservoir side, then put the line back in the reservoir and try it again.
Steve
Old Mar 21, 2012 | 01:53 PM
kmcn47's Avatar
Transmission: 5spd
idk if there replaced or not, hasn't worked since i got the car, i will try and prime everything though ad see if it works
Fronzizzle
Mar 18, 2019 08:29 PM
camaro11j
Sep 19, 2018 08:49 AM
Cripley
Aug 17, 2015 03:35 PM
sreZ28
Aug 14, 2015 07:48 PM
