mystery oil leak source
Car: 1991 Chevrolet Camaro Z/28 (Project
Engine: 5.0L 305
Transmission: 700R4 W/ B&M shift kit
I am leaking oil from an unknown source... the leak is coming from the top of the engine in the back on the passenger side and rolling down the bell housing and dripping on my exhaust and the ground the motor is a 305 any places to look at would be helpful.....I have checked the rear main seal, and the valve covers...not sure where to look next any suggestions would be helpful or if you need additional information
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Re: mystery oil leak source
Check the oil pressure sending unit. Drivers side next to the distributor. The car will probably need to be running for you to see it leaking.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
put some oil leak detector in your oil and put dem glasses on, probably the easiest way to find the source of the leak and fast.
Car: 82 Z28
Transmission: T400
Car: 82 Z28
Transmission: T400
Engine: 5.0L 305
ill be sure to check the back of the intake i capped off the oil pressure sending unit after the line snapped
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
yes, because all you need to do is darken the place or wait till night and put on the glasses that come with the leak detecting fluid and it should light off, not hard to find man
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
