convert 305 tpi to HO?
Old Mar 26, 2012 | 08:13 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
Is this possible? i had a 305 HO in an 87 monte SS and i loved it. lots of torque and high end power. I wonder if its possible to convert the 305 tpi (fresh reman) in my camaro to the same specs as the monte engine.
Old Mar 26, 2012 | 11:22 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: convert 305 tpi to HO?
Same specs, as in put a carb on it?
Old Mar 26, 2012 | 12:13 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
I know my monte had a carb, but i was wondering if i could get close with the tpi. i know if i change the cam i need a new prom.
Old Mar 26, 2012 | 12:22 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Maybe I am wrong but a stock TPI shoudl make 25-35 more hp than a carb HO montecarlo. Sounds like your TPI is not working right.
Old Mar 26, 2012 | 12:26 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
it probably isn't. i haven't had much of a chance to drive it though. i have been going through the painful process of un-doing alot of stupidity the PO left me to figure out. my last camaro was an 86 z28 that the PO had ripped off the tpi and carbed it. i guess ill finish fixing it and see how it goes.
Old Mar 26, 2012 | 12:40 PM
midias's Avatar
Yea get it running right I don't think you will want to go back to a CCC.
Old Mar 26, 2012 | 12:46 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
hopefully, all i have left is a new distributor.
Old Mar 26, 2012 | 01:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It already is, apart from the induction system.
Old Mar 26, 2012 | 02:12 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
so my 305 tpi is has nearly the same cam/pistons as the 305 HO?
Old Mar 26, 2012 | 02:14 PM
midias's Avatar
probably similar I think the monte SS made about 170hp and the TPI should be about 215 when working right. Getting the car to 305HO specs would be a downgrade.
Old Mar 26, 2012 | 02:28 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
guess it's a good thing i asked then. LOL. i guess this poor tpi has been abused and misused. the montecarlo used to break em loose with no effort.
Old Mar 26, 2012 | 02:36 PM
midias's Avatar
Just realized you have a TPI auto
87 Z28 A4 LB9 V8 9.3:1 5.0 (305) 190@4000 295@3200 TPI 2.73
Looks like you only get 190 not 215hp Also looks like you probably have 2.73 gears ouch. I think the 87SS got 3.73 gears and that would make a world of difference.
Old Mar 26, 2012 | 02:50 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
i am eventually planning on putting an IROC disk rear axle in this car. what was the gears in a third gen IROC rear?
Old Mar 26, 2012 | 02:56 PM
midias's Avatar
Changes from year to year could be 2.73 to 3.42.
https://www.thirdgen.org/tech-data
Here is a list of every year and rear option.
I think all bird L69s were 3.73
My friend has 2.73 on his mild 350 TA auto and second is a dog until her gets the RPMs up. 2.73 really slow the car.
Old Mar 26, 2012 | 03:04 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
im guessing this will lead to much higher RPMs on the highway.
Old Mar 26, 2012 | 03:06 PM
midias's Avatar
You got it. For an auto I would suggest staying around 3.40, 3.73 will make 1st way to steep IMHO.
Old Mar 26, 2012 | 03:07 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
It looks like the 87 305 M/T came with the same heads the 350 A/T had that same year. so if i can find those heasd it should really up the HP right?
Old Mar 26, 2012 | 03:09 PM
midias's Avatar
I don't know if that is correct. I thought all 305 heads were 58cc chambers and 350 were different but I could be VERY wrong.
Pull a valve cover and see what heads you have now. For a 305 you may just want to put in 1.94, 1.60 valves and give them a nice P&P.
Old Mar 26, 2012 | 03:16 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
I don't know if the volume is the same. good point. what heads do you suppose i should use on this and keep the lower end stock?
Old Mar 26, 2012 | 03:37 PM
midias's Avatar
The only aftermarket heads I can think of are trickflow and world products.
Personally I would punch them out for 1.94, 1.5 valves and port and polish them.
Old Mar 26, 2012 | 03:57 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
I suppose i should stab this new dist, see how it feels and go from there. not looking to race it, just drive it like a jack a$$.
Old Mar 26, 2012 | 03:59 PM
midias's Avatar
Step 1: Get it running right
Step 2: Save Money get the rear rebuilt with 3.42 gears
Step 3:
Step 4: Profit
jaridjohn
Jul 8, 2024 03:49 PM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
