Feul Tank
Old Mar 26, 2012 | 01:26 PM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Feul Tank
I have removed the Fuel tank as part of my full on restoration. Got a lot of gas in there which has been there for 2 years plus so need to get that out. My question is how do I get the gas out of the tank. I tried turning it upside down but as suspected that did not work. Must be a safety mechanism that stops the gas leaking out if the car is overturned. Tried to get a hose in through the spout but that did not work either. So how can I get it out?
Thanks.
Old Mar 26, 2012 | 01:30 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Re: Feul Tank
There's a baffle in there to prevent siphoning. Some here found a smaller 1/4 inch hose can get through but I never was successful with that method. Drop the tank, remove the sender assembly and drain.
Old Mar 26, 2012 | 01:39 PM
gholian's Avatar
Engine: 2.8 V6
Re: Feul Tank
Remove the sender assembly, how do I do that. Do I try to pry out the circular retaining ring around the sender with a screw driver? Are these tanks sealed so will removing the sender brake the seal or whatever else they used to seal the tank.
Thanks.
Old Mar 26, 2012 | 02:56 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Feul Tank
Thanks.
The retaining ring rotates to unlock it. Can use a dull punch and hammer to carefully rotate it. The seal is a rubber (buna-N) O-Ring, which if not damaged is reusable.
RBob.
Old Mar 26, 2012 | 02:59 PM
gholian's Avatar
Engine: 2.8 V6
Re: Feul Tank
Okay thanks. Will give it a go.
Bohemian
Aug 15, 2017 05:11 PM
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
kx3g
Sep 28, 2015 08:14 AM
lanceflame44
Sep 25, 2015 12:28 PM
