Need help identifying part
Old Mar 27, 2012 | 05:44 PM
KLSanchez's Avatar
Attached is a photo of the mystery valve in question. It's part of the distributor vacuum advance line; you can see there where it comes out from the TVS switch in the thermostat housing and into the carb.
Ride is a '79 El Camino 305 V8 (federal emissions package, pic also attached).
It looks like a regular distributor vacuum advance check valve with two extra ports sticking out the side. I'd like to replace it with a new one if I can, though if it's unnecessary I'll just delete the part.
Attached Thumbnails Need help identifying part-mysteryvalve.png   Need help identifying part-1979v8305federal-vaccuumlines.gif
Old Mar 27, 2012 | 06:18 PM
ex-x-fire's Avatar
Re: Need help identifying part
It delays the dist from getting vacuum advance til its warm, not sure what the exact name is, good luck finding one.A parts store might have a book you can look through. Me, I'd just hook up to strait vacuum & see how it runs.
Old Mar 27, 2012 | 06:24 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I believe it is called a thermo vacuum switch
Old Mar 28, 2012 | 08:21 AM
KLSanchez's Avatar
Searches for "thermo -" or "thermal vacuum switch" just brings up loads of ported vacuum switches, like the one to the left that it's hooked up to. I'm trying to figure out what the coin-shaped valve is and what it's proper name and/or part number might be. Personally, I figure the entire thing can probably be deleted completely and the vacuum line run straight from the distributor into the carb, but I'm hoping for some input from folks who've tried that before and what their experiences were/are.
Old Mar 28, 2012 | 06:19 PM
Edwardgp's Avatar
Engine: 454-350
All right I thought I had the answer for you, Sorry.
Old Mar 29, 2012 | 05:26 PM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
Variable air valve?
Old Mar 29, 2012 | 06:01 PM
Edwardgp's Avatar
Engine: 454-350
ported vacuum vavle
Old Mar 29, 2012 | 06:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Vacuum delay valve
Old Mar 30, 2012 | 09:20 AM
KLSanchez's Avatar
Apeiron nailed it. After using that name to search, I found the part is also called a "spark delay valve". It'll be easier to find a replacement searching using that name for it, as "vacuum switch", et al tend to point to ported vacuum switches.
I'm not sure folks were actually seeing it, but I circled the valve in question with a red circle in the pic to point out what I was trying to identify.
For posterity's reference: The spark delay valve is between the distributor and carburetor, with its two "disc" ports connected to a ported vacuum switch. From what I can see, all three ported vacuum switches on this emissions package are basically the same part and work the same, but the spark delay is tuning the distributor's vacuum signal and makes that particular line special. For further reference, car runs just fine with the line tied from the distributor directly into the carburetor, but I would figure the valve is in place for a good reason (likely to help it run smoother at cruising speed, and to retain acceleration, power, etc.). In the engine redress to come, two of the vacuum switches are going to be deleted, and the distributor line moved to the switch on the manifold, allowing me to delete the two plugs in the thermostat housing, too, by replacing it with a type that has no ports for vacuum switches. End result: less chaotic-looking motor.
Old Mar 30, 2012 | 01:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's to alter the vacuum advance behavior when the engine is cold. When the engine is warm, the TVS opens and bypasses the delay function.
LT1Formula
20
Nov 14, 2015 12:02 AM
Linson
Aug 21, 2015 02:12 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
